sach forks
robicon
Can some please measure their sach forks for me. from a 2010.
I need the length from centre for the axle to the mark where you would set the height on the upper clamp.
Thanks
Which mark at the top? I have a set here with TTX carts in them. Should be able to throw a tape measure along them for you in the next day or two.
The lower mark that is where I like to run. Thanks for the help, when I bought the bike I sent the forks and shock away to be set up only to find the fork where stripped on the inside. I didn't have a chance to measure these so when I did my conversion, so I was just guessing where to set them and the bike handle so well I didn't think about it.
Now I just had them serviced and the bike was feeling great but I found one of my bleeders was leaking and would keep a vacuum so it was sitting lower on the front and felt great. I replaced the bleeder and now it doesn't feel was good. I have my race sag at 110mm but I think the front is still to high.
Thanks for the help again jakobi
Sorry for the long turn around.
Length from centre axle to the top of the upper tbe (not including the the cap) is 935mm.
The lower mark on my forks is at 920mm (or 15mm below the cap). I have 5 lines marked into mine. Can't remember where I used to run them. From memory I think it may have been 9mm from the top.
