SAchs bushings
KYB 48mm
Available many yamahahaha models and select Honda CRF. Honda OEM seems to be the cheapest I've found.
Bushings, and seals all cross over.
Rick at Claxton Powersports in Salisbury Ma services my Sachs forks in a day or two so I have to assume that he has the seals in stock or are readily available.
HI all
I concerned by this issue right now. Can you write part numbers, or links to bushing, that will fit Sachs 2011 ec300? Or i just have to search for KYB 48mm and that's all?
HI all
Pick whichever bike you want that had 48mm KYBs fitted (open cart or closed chamber; both use the same).
Top of the head, parts fiche for 2009 CRF450R (the 250 and 450X used 47mm showas, not KYB).
