Hi there:
I'm partway through replacing the forks seals on my '11 EC250 which has the Sachs 48 mm forks. I have a couple of questions about refilling them with fork oil:
- when I pour the oil in, is it important to ensure none gets into the inner hole where the damping adjustment rod goes? Should I keep the rod in place when filling or does it not matter?
- I have seen videos where positive pressure (fork extended, hand over the top, puch top down creating pressure)) is used to get the air out, and others where a vacuum (fork closed, hand over the top, pull bottom down creating a vacum) is used to get the air out... which is correct? Or does it not matter?
Thanks,
Andy
Thanks,
Andy
