Hi
Just renewed the piston in my EC125 (08) and noticed coolant was passing from one of the front cylinder head bolts. Tried annealing the copper washers and refitted using a torque setting of 18.5lb/ft, found it was still leaking so ordered new copper washers, o rings for barrel and three o rings for the bracket which sits on top of the cylinder head, from gasgas uk, fitted everything tonight and I still have a leak!!
Wondered if anyone else has had the same problems, would you normally use some form of sealant with the copper washers?
Thanks
Kevin
Thanks
Kevin
