Shared engines.
Shaun1
I own a ec300 from 2007 that I am totally satisfied with!
The problem that I am facing now is that I cant find spare parts (ignition cover) for my gasser!
When I go into Motorcross Centre to find spare parts it only shows years from 2010 and forwards.
Does anyone know what years share the same motor and parts.
Thank you for all help.
Dude. There are despice manuals which I guess is Spanish for spares, check these out from links on this site and you can find part numbers and match years. There are a few people selling bits currently here.
I would be very surprised if the 2010 ignition cover doesn't fit the 2007, but as our friend F5 says, check the spare parts manuals.
What links are you referring to?
Suppose 05-13 has the same ignition cover because they share the same gasket.
I?m going to be forced to fix it it myself with some proxy glue till they open up all the borders here in Europe.
That cover on my 99,01, and 02 gassers were the same shape and interchangable but at some point before 07 it changed shape - they eliminated the rounded hump in the upper right corner (the hump was there to accomodate a counterbalancer).
do you remember if u had 3 or 4 bolts holding the cover on?
I found covers with 3 bolts, 4 bolts and with and without kickstarter (that it makes a difference) all with the same part number. Haha.
