Shift lever crossover
Hammerhead Designs makes one and X-Fun. I think the X-Fun needs to be sourced overseas, but the Hammerhead can be bought from them directly or from GoFasters.
I picked up a YZ 250-f steel Moose shifter from the local shop to try out and see if it fits
It looks close?? I'll post the results.
But, nice to know the RMZ shifter will work....that's good info:D
tmv makes one also and they are in the new 2010 parts unlimited book. priced write 39.95 retail
I'm running the TMV shifter on my bike. It is softer than stock and will bend fairly easy but the tip is much better than stock and the shifter stays tight on the shift shaft so I'm happy with it.
The YZ 250 shifter does not work, so I'll try the RMZ.
What lever is best with large boots?
I have the stock now and I always have to struggle to get my boot under the lever. I've raised it a bit but if I rise it more, it's way too up if I'm seated.
no shift lever for a japanese make will work, the screw that holds the shifter on the shift shaft is to close to the shaft on the gasgas, and you wont be able to get a bolt through it
