stainlesscycle
so, before i split the cases, it appears something is wrong with the trans on this 300 motor. it was shifting ok, and now it will only shift into 1st and neutral. i pulled the clutch, and try to manually turn the shift drum. no go. only 1st and neutral. i'm guessing a bent shift fork/bad shift barrell/something in there is bound up. any suggestions?
anyone have a good bottom end with crank/rod/trans that shifts fine? i dont need clutch/ignition/etc. it may be less expensive to buy a bottom end than replace parts.....
