shifter shaft c-clip
flybars
I have an after market shift lever on my newly purchase '03 ec250, and need to get a c-clip? to install in the shift shaft groove. Can someone please let me know what size it should be? Thanks in advance, Bob.
You really don't need that c-clip.
It's there to keep the shifter from sliding off. If the shifter is that loose, it will strip out anyway.
I'm too lazy to go measure mine right now, but I'd guess 8-9mm. Like Girard said its not critical, you could go get the closest standard size in a local hardware store and it would be fine.
