TavisB
Bronze Level Site Supporter
I needed to rejet my 2003 EC250 after I cleaned out my clogged up pipe and silencer. I'd been running a 38 pilot and 172 main most of the time, but with my newly better flowing exhaust that combo is too lean. I kept bumping both the pilot and main up until I settled at a 42 pilot and 178 main (I stopped here because I don't have any richer jets on hand). I haven't messed with the slide or needle. AFAIK the slide is the original #7 and the needle is on the middle clip (but I haven't verified).
I currently have the air screw at 1.25 turns out. With the 40 pilot I had to have it at 0.75 turns or I got a hanging idle. With the 42 at 1.25 I get no hanging idle, and no bog when I blip the throttle. However, I like the jetting crisp enough that I can blip the throttle in 2nd gear and easily loft the front wheel. With the way I have it set now it is a bit sluggish and doesn't get enough power to lift the wheel until I am guessing I'm off the pilot circuit and onto the needle. If I open the air screw to 1.5 turns + the idle hangs a bit at times and I get a bog if I snap open the throttle at low rpms.
Can anybody give me a hint to get it where I want it...not so lean I'm going to seize anything but with good throttle response right off the bat?
The temp is dropping fast around here so I'll probably wait until this weekend before I mess with it again.
