I'm selling a complete set of wheels with the older U-rims if your interested. They are set up for the newer axle size and have tight bearings.
Yes you have to have a gasgas wheel. Why not just buy a hub? Or a used wheel?
The older spacers are hard to tell the right way to put them in so when I did my first change I marked the outside.
Get those bad boys best wheels made EVER.
When you say "spacer" are you talking about the washer between the bearings or the actual "spacer tube" in the middle of the hub?
If the spacer tube then I was not aware that there is a wrong way to out that in.....
Agreed - the u-rims are fantastic. I wish they still made them. I have no idea why they quit making them...
I truly enjoy my GasGas EC250 (2006) it is rather indestructible, but apparently I have had an issue with my rear hub for a little while now and it is completely chewed up.
I am trying to avoid having to ship a hub or tire, and would like to find something locally, if possible. Do any any other brands cross reference to the GasGas rear tires?
bowhunter007
Posted 23 October 2012 - 02:11 PM
#16
If you own one of these older Gassers, do yourself a favor if storage isn't an issue. In my family, I got an '01 XC250, '03 EC250, & '01 SE300. All share many chassis and engine parts. I keep a '95 KX250 in the corner to rob parts off of, periodically. '94-'98 KX250 has many interchangeable parts for the older Gassers. I just purchased the '03 EC250. The jetting is way to lean for my riding conditions. The Kawi carb is the same, and has fatter jetting for where I live & ride. If all goes well, some minor tuning will have me back out riding with a nice tan plug. My KX is normally a running, rideable bike. So far, I've taken its brakes, rear plastics, carb, and the rear wheel currently resides on the XC250(w/54t sprocket, to account for the 19" wheel). The subframe and airbox can also be used on a Gasser.
note: I do put the KX back together, so as to keep it alive, once I receive the parts for whichever GG I'm working on.
My latest addition
