Speedometer reseting
ismael
Hi,
On my 2011 ec 300 all the functions on the speedometer are working but sometimes it shuts down and shows all the numbers. If I click the MODE button everything is fine except the hour goes to zero and all counters reset to zero. The total run time stays the same.
If I disconect the power supply, working only with the internal battery the same thing occurs.
Any thoughts?
Yes, it is. Sorry about the duplicate.
But I have already replaced the battery and the same thing happens.
This is the response I got from Trail Tech support.
"I would recommend placing a small piece of foam in between the back of the battery and the battery cover. This will make sure the battery does not lose contact with the meter. What is happening is when you are riding it hard the battery is vibrating and then loses contact with the meter causing the reset. Using the foam will stop this."
Will let you know if this works when I get a chance.
Later.
Later.
I usually use a bit of electrical tape, folded over itself a few times. Foam may work better though.
So I put a little bit of foam between the battery and the baterry cover and it didn't work.
But I found this wich is probably the cause of it. Broken wire on the cable coming from the bike.
