ggalex
With thanks to Clay for the following very useful info for baselining the suspension on the new 2012 XCs...
{Mod: Is this sticky-worthy?}
...I think you might be surprised how good these forks work with the odd set up I'm using. First get the springs correct. This is critical. Then back the clickers out all of the way and turn the pfp valve in one turn. I'm sure that Marzocchi did not intend to for the fork to be used this way but it really is working good for me and Zach, my son. I can not remember my front wheel running down a root in the last two national enduros. I think you guys should give this a try before you spend re-valve money.
Here is an approximate guide that I worked up on springs:
140 pounds stock front stock rear
160 pounds .44 5.4
180 pounds .46 5.6
200 pounds .48 5.8
220 pounds .50 6.0
240 pounds .52 6.2
260 pounds .54 6.4
The first number is the fork spring, second the shock spring.
Clay
