Hi guys.
2011 gasgas ec 300.
When riding last summer in Kamloops it was really hot. After riding hard up a hill and pulling clutch in to go downhill it would stall.
I turned the idle screw all the way in and it seemed to solve the problem, I idled a little higher and it was no big deal.
I am now realizing that it was a bandaid solution.
Ive installed a rekluce clutch and now it needs to idle properly, because if it idles too high the rekluce tries to engage. The guy who installed my rekluse said my carb settings were way out of tune so he fixed it. this guy has a good reputation for this kind of work.
After he adjusted my carb, i find i stall again like i did when it was hot last summer.
so i am supposing that i have a rich condition. i tried turning the mixture screw in as far as half a turn from buried but it still stalls.
Also, i notice that it almost has 2 idles. usually i run WOT then stop and id idles at 800rpm for arguments sake. Sometimes when i come off of WOT it will only idle at 500rpm, just barely holding on. 1 in 10 times it will stall.
Changed out the spark plug and it was kinda black and gunky.
Any advice?
Leaner pilot jet?
does this sound like a float bowl just barely out of spec, flooding the chamber?
2011 gasgas ec 300.
Any advice?
Leaner pilot jet?
