Starter question 2011 EC300
iamovru
Hello All
My question is about the starter. If I want to remove it, what do I need to put in its place as far as a cover is concerned. Parts numbers would be helpful.
Marc
Remove the parts and make a small plate to bolt in place of the old bendix cover plate or use a small automotive freeze plug to block off the starter motor spigot hole.
If you want it to be pretty buy the stock powervalve cover and the stock flywheel cover from the non-estart model.
Thanks Neil
I prefer pretty:D
