Starting point for N3CJ on 2011 ec 300.
Quigs
Currently running a JD Blue needle in my 2011 ec 300 but would like to give the N3CJ needle ago that I have.
Looking for a starting point.
38mm AS2 carb
Temp approx 10?c and elevation upto 1000ft.
Regards
Hey Quigs,I've been running the n3cj for years in my gasser 300's and have settled on a 178 main,42 pilot,middle (or 3rd clip on the needle) and finally air screw around 1.5 turns out.
This will be fine at your altitude and temps.
200m-1200m elevation and 10-35 deg celcius is the range I ride in with my combo, in our summer I'll raise the clip one position and still never been lean.
Don't forget your float level too!
I run the N3CH and I run a 42p and a 180 main. The main is still a little lean in the winter temps though
Can't find my 178 MJ so will order one tonight. Will also get a 45 pj just incase as temp's are 10 on a good day but can drop a little
