Steering Stops on powdercoated frames...
motogroove
Converting my 2001 xc300 frame from nickel plated to powdercoated, I notice my steering stops are going to quickly chew a hole in my powdercoating. The metal on metal was not a big deal on the plated frame, but now I wonder...:confused:
Is there any kind of bumper or soft something there on the new bikes? Is it metal on metal?
Maybe I could substitute a nylon bolt for the stop.
Hmmmmm...
What did you do with this, Dean?
I find myself in the same predicament. Find any cool hardware solutions for us?
Tim H
Tim, I would give this a try
Plasti Dip Synthetic Rubber Coating
DIY Synthetic Rubber Coating
Plasti Dip is a multi-purpose, air dry, specialty rubber coating. It can be easily applied by dipping, brushing, or spraying. Plasti Dip protective coating is ideal for a broad array of do-it-yourself projects around the home, garage, garden, and elsewhere. It protects coated items against moisture, acids, abrasion, corrosion, and skidding/slipping, and provides a comfortable, controlled grip. Plasti Dip remains flexible and stretchy over time, and will not crack or become brittle in extreme weather conditions. It has been tested and proven in temperatures from -30?F to 200?F.
My '07 has small plastic inserts in the cap screw heads for this purpose. I'm sure you could find something in Mcmaster for that. We do a lot with precision stainless tubing where I work. Its shipped with protective plastic caps of all sizes, and there are many of these laying around. If I can find something that will work I'll send them to you.
