Stock HEbo Bars 1-1/8 ?
biggstr6
Bronze Level Site Supporter
I searched the site and seemed to find two different answers on this . On the 08 EC300 Are the stock bars close to pro taper or Magura Bars?
The reason I ask ,I'm looking at getting moose contour bark busters and they couldn't tell which would fit hebo bars ,but theyre site list one for Pro taper,FMF,Tag,& Moose racing flex series CR-HI only.
a Different set for Magura& moose racing flex series except CR-Hi, and another set for Renthal,fatbar,& Nekken.
Anybody know which set would work for the hebo bars?
What Ronald said.
Especially after you cut your bar length down. Cause your clamps move inward where the bar is wider. At least that has been my experience.
Roscoe
FYI....
I purchased a set of Pro Taper CRM handguards for the new Gasser. Like always, I cut the stock 31 1/2" bars down to 29". The CRM guards WILL NOT FIT the stock GG bars if you cut them more than say 1/2". With what I cut off, the inside CRM mount needed to be right where the handlebar clamp bolts are. The CRMs are on a truck back to RMMC for a refund. I did find a set of Cycra composite guards at Cycle Gear for 20% off. They will fit. Probably not the strongest solution, but will do until I decide which bars to go with and/or the composites break.
