stay_upright
I've undone the nut on the LHS of the spindle and it looks like the RHS is a flat head with a cut-out for a weld to stop it spinning so you can tighten the nut.
Now i've tried hammering the spindle with a drift, putting the nut on and hammering a socket over the nut (this seems to give it a more solid wack) and also tried a puller on it but as the puller arms have nothing to hold I held the puller to the frame with jubilee clips and it snapped one of those.
Any ideas or options - since I don't think there is a problem with the bearings I could just put it back together. I did notice one of the spacers on the inside of the swingarm was cracked though and I'd like to strip and re-grease the bearings.
I also wondered if I could tap the RHS of the axle and try to pull it out with a bolt doing the work I guess if it fails I have lost nothing as the stripped threads are not needed normally anyway...
Do these normally seize or I was wondering if I could have bent it. I have a friend going to the states soon should I ask him to get me a bearing kit? They would be about 1/2 price there but of course I may not need it?
