SS109
Active member
Well, it finally happened to me. Went to go ride Sunday morning, hit the starter button, and thud. Thought my starter might have taken a dump until I pulled out the kicker and it was locked as well so I knew the crank stuffer bolt came out.
Anyway, the stuffer itself appears to be broken into two pieces. I tried removing the loose piece but it appears that part of the recessed area for the bolt is still on the broken piece and will not allow it to come out. Questions... can I just install another bolt with loctite and it will retain the separated piece? If not, can the stuffer be replaced with the crank assembled and in the engine?
Oh, here's a quick vid of what I'm talking about...
