Hi Folks,
Is it just me being thick or is the carb on an ec250 2006 an absolute bugger to get off and on again?
I have bought a FMF gnarly pipe for it, am I likely to have to re-jet?
Regards
John
With the slide removed, the top of the carb can then be rotated back toward the motor to expose the bottom of carb and remove the carb bowl
Hi Folks,
Regards
John
I very gently heat the airbox boot with a MAPP torch to allow it to flex more. Obviously there is gas around, so do this at your own risk and with a fire extinguisher handy.
What!
Crazy man. MAPP is well hot!!! A hot air gun maybe.
I got sick of wasting time with boot so I just swing the sub frame up and its easy.Lot easier if you can loosen the subframe and pull it up a little to clear the airbox.
