Temporary Loud Exhaust Noise????
Canadaler
Was out trail riding on my '10 EC300 and when gassing it while rounding a (slightly uphill) corner all of a sudden my bike sounded like the silencer had fallen off. Seemed like it lost power as well.
I reached back with my right hand and yep...it was still there, but I immediately pulled off the trail and shut off the bike. Got off to inspect, assuming that the silencer had separated from the pipe at the stinger...but no.
After looking over the bike and finding nothing wrong I fired it up again and it sounded like I didn't have a silencer....??????
Walked back down the trail to see if maybe the packing somehow got blown out but didn't find anything. About this time my buddies came back looking for me and I started the bike again...still very loud.
After scratching our heads for a while to figure it out...I figured on riding back to the car. Started it up...and no noise. Bike ran fine the rest of the day and on two more rides subsequent to that ride.
Power valve issue maybe? Allowing raw mixture into the pipe where it ignited maybe?
I'm stumped.
What pre mix oil and ratjo are you Sad Power Valve Foulers using ?
I used Ipone strawberry smell oil (2%) when had problems with stuck open powervalve. Stop using ipone and change to BradPenn (2.5%) oil and not problem seemed since..
Sent from Razr MAXX
Thanks guys.
Hmmmm....running Ipone strawberry at 2% here as well...makes you wonder doesn't it?
After using strawberry ipone i opened cylinder (change piston) and pv. Pv was covered quite hard carbon, not sure how it looks now after using 60hrs BradPenn oil. But at least it work without any issues. We will see that when i change piston somewhere near 100hrs on it...
Sent from Razr MAXX
me too
2010 300'
Mine does the exact same thing except it occurs when uphill and hitting a large root or rock.
A little revving fixes it.
Time to clean up my PV
Me and my brothers bike did this same thing, we both have 2011 300's. the bearings on both sides of our powervalve were bad. The three bearings are only like $20.
I think it can be only carbon in bearings too, if open type bearings. With my ex bike 2009 300ec bearings was good but powervalves other parts are very carboned and getting stuck.
