My cable once got out of place in the slide on the older carb AS1 and took up free play. Check that or cable routing pulling on the cable out of the normal place of routing.
Keep your free play to 1mm Max. I always felt comfortable having about 5mm, but more than once this has caused the throttle to stick open after a landing, and with no push left in the cable it just sits partly open... I.e. "fuck this" and jump off the bike!!!
Would also safety wire cable at both ends if you ride trails with
A lot of plant growth. Would make it "interesting" if cable got hooked up on a branch.
