tip on changing rear link bars
And it only took you 2 hrs and 9 mins.
:D
make sure the bottom shock mount bolt isn't rubbing any of the linkage. On my 06 300 if you put the bolt in the wrong way the head of the bolt slightly rubs the linkage arm. The clearance even when installed correctly is amazingly tight ... just something to check .....
thx skid I will check
Something looks wrong. The link bolts should both be oriented the same way - the bolt head should be on the same side. Look in the parts manual.
Eric, I have put them together both ways, I can't see how iut would mtter. Having said that on my 07 which just got a swinarm lube the shock mount bolt is way to tight to the linkgage. I am going to take a mm or two off of it.
