Would a slighty used Michelin 140 fit on a 200 a lot off trouble? I don't as a rule even remount rear tires but times ure tough. Will it work, tire too big, any suggestions helpful.
Thanks,
Jim
biggest i have had is michelin 130/80 mounted in the past.. i do not know if bigger will rub silencer on bottom out...i think michelin 140/80 is same as metric 120/100 (or 90?)
