Trail Tech bike computer
I recently got a trail tech, my stock speedo pick up was broken off near the lower caliper mount bolt, drilled it and used an easy out to remove, screwed the trail tech pick up in, had to dril the rotor for the magnet, I have very good drill bits and that rotor is hard!, glued the magnet in with jb weld. the trail tech is great, so much better than the stock speedo.
Hey Guys,
Just wanted to thank everyone who responded to this thread. I think the guy before me had drilled out the hole where the sensor goes for some reason. I ended up taking the plastic piece seen in the first set of pictures, cutting the end off, and using it like a sleeve to make the new sensor fit in the hole. I epoxied the two together and JB welded the receiver magnet in the right spot and FINALLY! I took it out on the trails today and it worked great!
One of my favorite parts about owning a Gas Gas is the friendly and knowledgeable folks on this board.
Thanks Again!
Sam
