TrailTricks Sachs $300
tnttimber
Trail Tricks valved Sachs shock in great shape set up for 190 pounds. It's off my 2010 gasser 250 that I sold with ohlins on it.
$300
Nate
You guys will need the lower clamp as well too, they will not fit the 45 clamp.
This is a shock. You won't need anything additional to mount it. It will definatly work on a 2011 and Im prety sure it will work for an 07 also.
Nate was this one better or worse after the work than the ohlins?
The ohlins ttx is in a different league. The trail tricks sachs worked better than any other stock style shock I've tried. The ohlins ttx was extremely adjustable and it was much more complex to get it setup than the sachs.
This is a very good shock and I'm offering it at the price of the revalve alone, trail tricks isn't cheap.
Ah!, I didn't catch that you had replaced with a TTX. The 888 on mine is not the best, if I don't make serious progress getting it setup this weekend...
