Triple clamp diameter
Does anybody know the id of the upper and lower triple on the 2018+GG/rieju mr
I’ve acquired a set of kybs from an 08 250f to swap onto my 06 ec300. I know that the yz triple is an easy swap on but I’d rather keep it gg if I can.
Why throw money at it? Better to keep it for a revalve if your riding is more trail than mx orientation. Made wonders on mine and sss were great forks for single track after.
Mine is from page 3 with pictures. As below. We get there and results are better than expected
So, let me see if I have this straight... you have the 45mm Shivers on your '06 and want to swap to '08 KYB 48's but want to use '18+ GasGas/Rieju triple clamps, yes?
Personally, I think they will fit (GG KYB clamps/Yamaha KYB forks) but I really don't see the point in buying GG/Rieju triples. Easiest way to find out is have someone with the modern GG/Rieju measure the forks where they go in to the clamps and compare that to where the Yamaha forks would mount in the clamps. If I had my buddy's '22 Rieju here I would do it for you but, alas, I don't.
Yeah im replacing the 45mm zokes with the 08 kybs but would rather to use the 18+ gg/reiju t clamp over the yz clamps if possible. If the 18+ t clamps are 56mm top and 59mm bottom the 08 kybs will bolt right on. I’m just finding conflicting info on the id of the top clamp whether it’s 54mm or 56mm and would some confirmation on its size
Mine is from page 3 with pictures. As below. We get there and results are better than expected at the end.
Long thread
The bike is an 06 with thousands of miles at race pace, the zokes are roached beyond belief. It's just not practical to put any more money in em(needs bushings and seals). They’ve worked great for nearly 2 decades but it’s time for an upgrade. Also for some reason maybe it’s just me but I can’t open that link you sent.
Ah, sorry, site was changed, but I found it with search here so can't explain that (?!).
I explain, on another posters KYB thread how I fit SSS on my old 07. This is a good endeavor. Lose the shivers.
I used YZ clamps and bolt and weld on blocks for steering stops. Just thought it would be cheaper for you.
Unless they are cheap for some reason.
The upper bearing was a YZ one. I needed a Braking brand caliper bracket to line the disc up.
I loved the result after revalve.
I went from 48 Sachs to KYB SSS and only had about 1mm shaved of my top triple clamp. measure your existing forks, and see if there is enough meat on the existing clamps to have them machined thinner.
I also had a yz axle and wheel spacer machined to match my GG hub as i did not have a yz wheel
Yes, got distracted but remembered I used the YZ axle and turned a couple of 22(?)mm spacers. Equal on both sides.
I had to fit bigger ID bearings in gasgas wheel.
07 Triple were not big enough to skim.
On my mate's 2010 they were so we (paid to have that done) took out 1mm all round and he just slotted the YZ front, wheel brake and all in place.
I used the Yamaha triples, but GG wheel. Had to make spacers for the front axle plus a 10mm smaller brake disk to avoid using a non-standard caliper bracket.
When I did the KYB swap on my 2011 GG. I just swapped the entire YZ front end. Wheel, triple clamps, caliper and forks.
Ended up just getting the T clamps milled to fit the kybs, welded and re drilled/tapped front caliper bracket, made custom wheel spacers to fit the gg wheel and she’s good to go. Not missing the old zokes one bit
Oh yes. Much better than the zokes.
But if you ride single track there's an improvement as big in getting a revalve.
I guess I'm one of the weird ones as I actually liked the Zoke 45 Shivers. Liked them better than my buddy's Yamaha SSS KYB's that he's had done by AEO. I've run a lot of different forks and have found all are good if you get someone who actually knows what they are doing with a re-valve. Well, except for the WP 4CS forks, of course. :giggle:
I actually like the 45 shivers a lot but it’s not easy to find spare parts for em, I need new upper tubes and GG/Rieju prices are crazy high. Few years ago I bought cannondale zokes for spares but ended up putting them on my 98 ec250 to replace the 45 magnums. So far my two sets of shivers(valving specs similiar to gmp, IIrc) I got perform wayyy better than the kybs in slow paced/ nastier rocky trails but the higher speeds on single track or double the kybs blow the zokes out the water.
Few more rides on em before the season kinda ends and then I’ll get em revalved, most likely by WER since they’re local to me.
Bihgest difference for me was stutter bumps. The zokes had been revalve to cope with wet tree roots on single track which they weren't very good at std. But my elbows always used to feel beat up at the end, or before, of the day.
YZ forks put a complete stop to that.
