Leon Hi again!
My forks have been revalved by the gasgas agent and have greatly improved from the original settings, which were very quick in the rebound and would blow through the stroke very easily. As they are set up now, they offer good tracking through the rooted rocky trails but still are too soft for high speed scrambles and light MX. I might just swap one stock spring with a 45 one to get an overall rating of 43.5, or put both 45's and replace the preload ring with a thinner one and lower the oil level to 130mm. I will keep you informed anyway.
The rear sag is at 110mm and is very very compliant. BTW it also was revalved since it was loosing all its damping after 30 minutes and was like a pogo stick. I ended up in some trees coming down a steep downhill, it was just all over the place.
Concerning the new standard 2010 Sachs forks, I can say that they offer just that much more rigidity required but are as compliant as the marzocchis in the rooted trails, much like 2008 WP's. I had a chance to ride a 2009 racing 300 as well which was terribly stiff, both front and rear, and the owner had them set at fully soft, they had a lot of sticktion even with over 50 hrs on them, night and day with the '10 fork. Owner was very very frustrated!
