Using Flexx Bars with handguards?
roostafish
Has anyone used the Flexx Bar with Fastway FIT handguards? I'm not sure if this will work. I do know that you can buy handguard mounts for the pivot on the fasstco website, but if I can use what I have, I'll avoid chunking down an additional $80. The bars are expensive enough as it is.
Also, does anyone have the bends figured out for these? I don't know how much sweep to get. I like the old standard CR High bend. I currently run the Enduro high Pro Taper.
Thanks.
I used some old bar mount tops when I set my handguards up. They are holding up quite well and have been well tested numerous times and one is just bent a little. MIne ride on a stack of teflon washers over a good grade bolt. Buy the bars and make your own mounts. I have no idea what bend mine are as they came on the bike. I do know they are sweet and you notice them most when you ride a bike without them.
I have that setup on my KTM and it works alright, but not as good if you buy some of the various setups available through Fasstco. I use the handguard hitch on my Gasgas and they now have Cycra CRM handguards which should be ideal with the handguard hitch.
