pscook Platinum Level Site Supporter Mar 31, 2014 #2 Look at the 1994-1998 KX250 unit, it fit right onto my 200 300, which had a KX250 rear fender. It might be close enough to make work.
J Jacob 'Berg Member Mar 31, 2014 #3 pscook said: Look at the 1994-1998 KX250 unit, it fit right onto my 200 300, which had a KX250 rear fender. It might be close enough to make work. Click to expand... Thanks, Green plastics on a gasser?
pscook Platinum Level Site Supporter Mar 31, 2014 #4 Jacob 'Berg said: Thanks, Green plastics on a gasser? Click to expand... Nope, it was a black fender. Perfect fit, even with the 2005 GG side plates.
Fred1956 New member Mar 31, 2014 #5 Jacob 'Berg said: Looking for a splash guard/mud flap for an 05 EC 300. Click to expand... Are you looking for the rear fender or the shock protector (in front of the swingarm) ??
J Jacob 'Berg Member Mar 31, 2014 #6 Fred1956 said: Are you looking for the rear fender or the shock protector (in front of the swingarm) ?? Click to expand... The splash guard behind the rear shock. Protects the rear shock from debris being thrown by the rear tire. Bolts up to the rear fender I believe.
motorhead Member Apr 7, 2014 #7 pscook said: Look at the 1994-1998 KX250 unit, it fit right onto my 200 300, which had a KX250 rear fender. It might be close enough to make work. Click to expand... Just bolted up a polisport mud flap from somewhere in the above range of KX 250's on my 05' 300. Very similar to stock GG part, works just fine- no issues.
Fred1956 New member Apr 7, 2014 #8 Jacob 'Berg said: The splash guard behind the rear shock. Protects the rear shock from debris being thrown by the rear tire. Bolts up to the rear fender I believe. Click to expand... The OEM one is like $13 at GoFasters I believe
J Jacob 'Berg Member Apr 10, 2014 #10 twowheels said: PM me. I've got them in stock. Click to expand... I bought a kx 250 splash gaurd for $13.50 before I saw this post. If does not fit up well I will be in touch.
