hi guys,
i was under the impression that i had a 36mm keihin AS1 carb on my gasser ec 200 (2001) is this so?
allso i wanted to know what were the 2 diameters of the carb in- and outlet.
(side of the engine and side of the air filter.
can't find it
Black screw on top is AS I. There was no such thing as an AS II in '01. As far as I know ALL were 38mm, but you can measure the ID of the spigot end to be sure. External dimmensions are the same for 36 - 38mm.
Guys that have swapped 36mm to 200s have had good results.
I got 38.25mm for mine ('06 EC200, black screwtop carb), but did wonder if I should be measuring the ID closer to middle, nearer the main jet, where it looks to narrow to a constant diameter.
