I need both sprockets and I can only find for years after 2000 and after 2003. No one lists anything far back.
Were there any changes between years? I find some conflicting information. Some say yes others no.
Thanks, I searched for a while and gave up.
I have used the following sprockets on my 99 EC 200
The Husky's use this part number as well. Starting on page 29/30
http://afam.com/images/downloads/catalogue/afam_cat_2012.pdf
Go to page 15/16 for the GasGas, it does no list the 99, starts at 2000. They are the same.
AFAM # 15206- is aluminum 14206 is steel sprocket. I have also used the AFAM c/s sprocket as well with NO issue. It's all there in black and white.
I have also used Sprockets Specialist rear aluminum=
don't go there, they wear like butter=-SUCK
I have used PBI as well.....no a fan favorite of mine.
The Dirt Tricks have been a favorite of some folks here, but there was a issue with the c/s and the spline's, = premature wear on the shaft, c/s getting sloppy.
I am currently using the Talon c/s and a AFAM aluminum rear and a X ring chain....good stuff.....
Renthal uses the same part number for the GasGas and Husky...... never used that line before....
http://www.renthal.com/File/fit_my_bike_process.asp?tabtype=2&manufacturer=HUSQVARNA&model=CR 125&bikedate=1998&zone=USA&biketype=Off Road
http://www.renthal.com/File/fit_my_bike_process.asp?tabtype=2&manufacturer=GAS GAS&model=EC 200 Enduro&bikedate=1999&zone=North America (Canada)&biketype=Off Road
Hope that helps
