where to buy plastics
earlystock
Wrecked my 2014 300 today and needing to find left side shroud and number plate. I can't seem to find anywhere to order them and the search isn't working on my phone right now. There is no dealer even remotely close to me anymore so can't just pop in and order the parts unfortunately. Another help would be what shifter crosses over, broke off the tip of it today as well.
Thanks, halls was who was going to call if needed. And as far as the shifter goes is there a crossover that I can get an aftermarket one that would be stronger? I have seen where I could get the stock one but was hoping that a yamaha or something would fit.
Yep Hall will have it.
This it what I have been using for shifters. The only problem I have had is the gap that pinches it to the spline I guess stretches I have had them get loos if I take them off. When that happens I just run my grinder with a cutting wheel to increasing the gap and it does not seem to happen anymore.
http://www.ebay.com/itm/EMGO-ALUMIN...ash=item54250e2801:g:GiYAAOSw34FVDZh3&vxp=mtr
+1 on the emgo shifter, they work well and are reasonably priced. Like Rod says check to see if it comes loose. I have used this shifter on my 550 fe also, and if the shifter comes loose it will strip the splines on the aluminum shifter.
