Where to find a sachs shock spring?
bergerhag
Ok, got my 2010 EC300 dismantled to change the shock spring, i need a 58N/mm. Got one from my local dealer, who got recommendations from the importer, it was a racetech kyb/showa spring. It didnt fit. It was too tall, and a little to wide in one end.
Is there a supplier of sachs springs somewhere?
You have to machine the spring retainers if you want to use the ohlins as the 2mm smaller ID. Other than that you can go to a Husky dealer, which is what I did.
I got another lead too, TM has the sachs boge rear shock also.
But why, Gasgas factory, aren't you supplying springs in different rates?
