Ryderod
Howdy, I have an 07/08 (not sure) EC300, love the bike, very smooth power and great traction in tech stuff, the only non standard item on the bike is the rear canister. The original straight shaped tailpiece fell apart and I got hold of the old type banana shape pipe for a good price.
Sprocket combination is 13/52.
I have recently added a 2011 EC300 to my stable, this is running the stock FMF canister.
Sprocket combination is 13/50.
The power delivery on this 2011 bike seems a lot more aggressive, the bike feels snappier, almost like my old YZ, with the rear spinning out easier, and the front lifting easier than my older Gasser.
I would have though that the longer gearing would have smoothed out the 2011. I also notice that the mapping seems to make more of a difference on the older bike, with there being nearly a stutter or bog when revving up set in tech mode, which works quite effectively. The mapping on the 2011 seems to have virtually no noticeable effect no matter where it is set.
Is there a difference in flywheel weights between the two models, and could that banana pipe be responsible for the bulk of the difference? Any other areas I should look at?
I would like to try get the 2011 as smooth as the older bike..
