300 rebuild
sorry guys i've been at work, since my last post i've had a few things happen, the frame was stripped of all mounts and the bottom tubes replaced and braced, then i was told about an open day at the local track so i bolted it all back together at the last minute to go for a ride on the race track, everyhing going well, i did a compresion check with a meter and it didn't have pressure just a percentage, it said 100%, i'm not sure wether its 100% good or bad. any way i took it to the track 7 hours after it was finished and got it scrutineered and passed, alot of people were impressed i got it together and running, got onto the start line, 15 second board came up, then it all went wrong, throttle jammed on flat out which blew the reeds out the wrong way
, and shut down on the line. i quickly got to the pits and put a new cable on but no spare reeds. oh well. i've now ordered the reeds and got the local gasgas dealer to price up all my bits for the motor rebuild.
The counter balance shafts are an issue but what it was that bit me was the screws that hold the alternator windings in the cover let go into the counter balance weight on the left side which temporarily stoped it at 10-15000rpm, not sure but i know i was going fast, it snapped the key and welded the gear in the right side of the shaft but welded it 180" out of sync. the nut came off and also dropped to the bottom of the clutch cover luckily not breaking anyting else. i took the shaft out and capped the holes but after runing it without it i might be putting it back in if i can get one from the supplier a i had to cut mine out.
I havn't done my A-arms, i just got bigger forearms. i like the steering the way it is, its good for high speed which is mostly what i do. can you PM me the details of the A-arm mod anyway just so if i want to i know what to do.
Cheers Guys and thanks for your help so far.
Bill
