M MBevans New member Jan 24, 2011 #1 Hello all, I'm looking for a engine for my 2005 MC250. I found this engine and the seller states that it will fit a 2001-2005, slightly confused as I throught the 2005 was a "change" year, no?? Thanks in advance, Mark Attachments GASGAS #2.jpg 30 KB · Views: 32 GASGAS #1.jpg 30.9 KB · Views: 33
GMP Active member Jan 24, 2011 #2 Looks like an '05+ motor to me so you should be good. You are correct, the case design was changed in '05.
E einsteingarage New member Jan 24, 2011 #3 I can tell you that you will have to modify your frame if it's an 04 - 01 motor but only the bottom tab by the shifter. I still have my 05 frame set up for an 04 motor if that's what you want to do let me know.
