A trick I've used for years with success on all all the forks mentioned:
Wrap a piece of nylon cord, 1/8" dia, packed with seal grease, around the fork tube under the dust wiper. This will catch anything that the wiper passes. Clean and regrease occasionally. Two seasons on seals should be no problem. Use OEM seals.
WP easiest to service. Zokes not much harder. Ohlins a PIA and needs special tools.
