thejackrabbit
I'm looking for a 2011 - 2014 headlight, this would be the part that holds the bulb. the part numbers for those years are the same so I assume the same part(although not always the case with GG
I also need the screws for mounting and the lower screw with a spring, I will be using 2011 plastic number pate so the bottom bracketry associated with the 2012-2014 will not be needed.
i do not need the plastic number plate that the headlight sits inside.
please PM me. thanks
