Wtb Ecu
trxpeter
I'm looking for a 07 ECU for a 450. The last of the Marrelli units.
USA or Aussie would be best but open to anything . Cheers...Peter.
What happened to the original?
The reason I ask is I have just bought a non working one from an 03 for a project and the only fault on it when I took it apart was a dry joint on the vr/micro reset chip. If yours is allegedly blown it may just be something simple?
If you prise the tin plate off the front and remove the circuitboard from the casting it is also worth checking where the socket is soldered on. This one is "iffy" there as well. Bring back leaded solder!!! The Vr/micro reset chip is located to the right of the connector socket. This is with the main component side up and the socket at the bottom. If it doesnt work still at least you request gets another bump!
