WTB gas cap assembly
Put it back together.
Its just a cap. Scrap the rubber insert. They shrink and don't seal anyway (either make your own, or do like I do and run without). The rest is a single ball bearing and a plastic cap with a small hole in it that slides on. Pop the ball bearing back in. Bit of glue around the bottom, plastic cap back on. DONE! If you've lost them I have a spare ball bearing and cap here but here is Australia and the postage would cost more than the parts depending on where you are.
New edition in stock. The ball has moved out of the cap - the one-way vent is in the hose ala Yamaha now.
PM sent.
