I broke off the bolt extractor bit inside the bolt trying to back it out, now I have hardened steel inside of it that will be tough to drill out. It's the top left bolt. After my ride this weekend, my plan is to work on the bolt head with a drill bit to release the pressure on the pinch clamp or use a dremel tool to cut the bolt where it pinches together. I tried JB welding an allen wrench, but that didn't work either. I may try the tap / heli coil option, but if someone on the forum has upgraded triple clamps and has the oem sitting around they don't need, this may be an easier option versus trying to get through the hardened extractor bit. All this for a GPR stabilizer.... Cascade Crawler, I have shot you a pm.
