YZ kicker ???
i have one on mine. It gives a little more leverage, not that mine was that hard to start anyway.. I was destroying my rh boot on the peg, prolly something i was doing wierd kicking it..
I bought one for a friends 07 250, It's easier to find a cheap yz kick I think that's the main advantage is price.
I'm having the same problem, my boot is getting shredded. Going to order a YZ one this week.
The kickstarter was changed along the way - the older ones were really short and didn't have enough "meat" where the arm met the knuckle when it was folded back - so it would sometimes break down and fold backwards.
They are now longer and stronger - so the difference between a newer GG kicker and the YZ kicker is less.
I only have experience going from the really short old one on '01 to the YZ kicker...
Comparison in kick levers
Here is the GG OE kicker on my '07 EC250:
Here is the YZ kicker on my '01 XC250:
YZ starter knuckle is also closed at the top and sealed at the bottom with an o-ring, so it stays tight longer with less maintenance.
KTM Kick Starter
I use a KTM 525 (04) kick starter on my 250 ec (07) - no mods required, fits straight on.
Watch the KTM starter does not loosen. The GG shaft is tapered slightly and is what the knuckle is torqued against. The KTM knuckle is a little narrow. I had to use a few 17mm ID shims to make up space when I had one. Good durable starter though.
does a yz 250f fit straight on?
It fits '06 300 & '01 300 splines spot on.
There was a slight amount I filed on the edge of the kick lever to make sure I had enough clearance to the case by the clutch cover when the kick lever swings in.
Thanks should be good for my 300 06:)..i`m too tight to buy a new gasser one @ ?98
