'02 EC300 brake light wiring
brider
My '02 EC300 appears to have the original harness mostly zip-tied away around the gas tank &n airbox, but the headlight is still there and flick on with a little toggle switch under the fairing/number plate......not sure if it's factory or not.....
But the rear fender has a tiny light on it, no license-plate holder, but that tiny light is there with it's harness & plug, but NO harness from a brake switch is attached to it. If that tiny light is a brake light, I'd like to get it working again. Is the factory wiring diagram and/or parts manual a reliable place to start? The fact that the bike has a working headlight encourages me, there is no speedo or instrument of any kind, is it even possible to scrounge instruments up and make them functional?
Likely your 2002 GasGas300 is either the XC or DE model if sold in the USA.
It did not come with the full wiring harness for the brake, turn and lighting.
This is how my 2002 XC300 was delivered. It came with a 2K2 stator and not
the 2K3 stator of the EC300 model.
I bought the complete wiring harness, Added the 2K3 stator and did the floating
ground modification. Added a rectifier/regulator and battery.
Some where there is a post thread describing the process I did. Something about
AC/DC conversion. It was a rather involved process and a fair amount of work with
more than a few new parts required. Horn, Handlebar switch gear, Banjo bolt pressure
switches, turn signal flasher unit. Two bulb rear light with running light and brake light.
For me it was worth the cost and work involved.
Good luck, Jeff
Not that you asked, but, the wiring harness I recently purchased was
BE250334004 for the Rieju models. I got it from Matto Cycle.
To get a brake light you would not need to do the AC/DC conversion
I mentioned above. I suppose you could tap into the existing harness and
make your own harness for the brakes. Still would need the pressure
switches and tail light housing.
I could not find my old post in the archives for my conversion project.
I think it was from around 2009?
Good luck. Jeff
OK, back to this topic:
My EC 300 ( I actually think it's an '03) HAS the factory headlight AND 2-bulb tail light on the rear fender.
My goal is to wire to the running light of the tail light so that when I turn the headlight on, the tail light running light comes on. Easy enough.
But the rear brake light is the challenge, and looking thru the parts list from this site for the 2004 model, I see NO parts for the brake switch anywhere. Assuming there is power somewhere in the disconnected harness that is zip-tied up under the seat and front rad shroud(s), is there an aftermarket pressure-switch I can adapt, or a factory GG switch from a later year that will work? The existing rear light has a factory 3-prong connector, ground, running light, brake light.
Yes, there are banjo bolts with bulit-in pressure switch. That is what I had on my 2015 model before removing everything but the headlight. Those are OEM equipment. Part number BE250334003.
Thanks, I found the OEM P/N right after I posted, should've looked more closely at the brake-parts illustration instead of the wiring illustration.
ALSO: Kind of un-related to the posting title, but can anyone suggest an alternate to the factory BE250234015 rear light assy? Parts list has EC300 application for a rear license holder, but NO effectivity for the light....and that light P/N does not show up in any on-line searches:
I bought a universal under the fender mud flap with built in tail light from somewhere I forget . Maybe it was polisport brand ?
I copied your description and pasted into a search and found this:
VERY sketchy-looking source but it's really what I'm looking for, thanks for that suggestion!
Edit: Just noticed it's "free" shipping from China......not sure how much faith I have in that, might look further for a domestic or EU source.
So, here is a similar item on Amazon (of course) for dirt-cheap, which is my kinda price. But a general question:
How do people mount a standard US-issue motorcycle plate on any of these mounts, where none of them seem to have the surface area or shape to accept a plate, no matter how you try to mount it? (red or blue):
Have you gotten anywhere with your lighting problems? Brand new oem harness is 40€ and absolutely worth the investment to have a clean and fully working harness on your bike.
