07 gasket kit into a 09?
lonetree
there are no engine changes over these years are there?
im sure that a 07 gasket kit will be fine in the 09.... (bottom end that is)
supplier says only up to 07??????? :confused:
Should be fine. If you run into any problems shoot me a message. I have a complete engine rebuild kit here. The only real change I can think of is that the water pump changed on the 09-2010 model, but I think that may just be external too.
The gasket kit fits from 2005-2011. Your good. Part number of ME250544100 I think they put 2 water pump gaskets in that kit one for old and one for new style. A quick check is if you find a part on the microfiche that starts **2505 mean fits from 2005 or **259 means fits from 1999. Just a tidbit of info.
