husley Bronze Level Site Supporter Jun 13, 2016 #1 I am considering putting my 09' 200 motor into my 10' 300 frame. I believe there were some frame changes between 09' and 10' ? Will swapping motors/cdi/exhaust between the two be as easy as just swapping the parts ? Thanks J
Stoby Bronze Level Site Supporter Jun 13, 2016 #2 same All the cases from 04 up should be the same 200-300 . Pipe I'm not sure but I believe it should be same check fmf part numbers to be sure. If not all you have to do is change - fabricate mounts.
