What pilot are you running with the cck needle?
The reason I ask is that you will probably find things will work better if you back off the idle - go up on the pilot to a 42 or 45.... I would start at 2 1/2 to 2 3/4 on air screw.
MJC. Can you rip out some part numbers for the Kawi needles? I'm interested in trying one. Sounds like just what I'm after (or maybe a #8 slide.. mmm).
I like the NEDW in my 250. Nice smooth power off the bottom that continues to build. It'll bring the front wheel up in 6th with 13/50 gearing.
NEDW is good for 250,but for 300 pwk 38 ASl witch one (NExx) to put in? I read all posts regarding suzi needles,for someone( 300 pwk 38 ASI) is good J,for another W but ai saw somewhere you say: J,W it lean,witch taper to use J,W,H,G?
