14 front sproket
gg3
Learnt a lesson on my 2010 ec300 today.Brought a nice Renthal 14 front sproket to experiment getting the gearing a bit wider.Cheaper than replacing a rear sproket.It doesn't fit! It touches the clutch assembly.
Thought it is worth writing up if anyone else was thinking the same.
The rear sprocket for a 1991-1993 suzuki dr250S fits GG enduro bikes (I have one on my 300). They are still made by JT Sprockets and Primary Drive and others. I picked up a 49 tooth rear(steel) for less than the cost of a front sprocket. They also come in a 42 tooth sprocket which would give you a drive ratio close to what the 14 counter shaft sprocket would have.
P.S. The dr250 and the dr250S use different sprockets and only the "S" model fits.
Your 2010 may be a different distance from the counter shaft
sprocket axis to the clutch hyd. master cylinder than my
1999 EC250. At least on my bike it is possible to mount a 14
tooth countershaft sprocket.
See the thread:
http://www.gasgasrider.org/forum/showthread.php?t=5077
for a picture.
I had to remove the swing arm pivot bolt and slide back the
swing arm to get it to mount.
As well as using a dremel grinder to remove maybe .03-.05 In.
of material from the master cyl.
I am using 14/40 gearing on my EC250SM Motard.
I like it. It was worth the effort for my purposes.
Jeff
I'm too chicken shit to take a grinder to my new bike.I am hoping for a similar result with a 13/46 combo.Noobi gave me a good contact.
this might help for selecting the right size rear sproket to get the same gear ratio
What kind of riding do you do??? Most of go the other way like 13/50, 13/51 or 13/52.
Yeah, I'm intrigued too. I would like it if the ratios were spaced out a little more. I'd like a slightly lower 1st gear, but I don't want to lower the whole lot. After all, it's such a torquey motor it could handle a wider spread.
Excellent chart Swazi.thanks.
Just an experiment to see how it works.Alot of ktm 300 guys run a 14 front(but they are a gear short).Theory is it spaces out the gears,longer 1st/2nd for smoother riding in tight stuff ,holds a gear longer through corners & less wheel spin on hills.
Definetly wouldn't want to go lower,it would make 1st almost useless except for pulling KTM's out of bogs.I will let you know how it goes.
Interesting - don't you often wish for a lower 1st gear when you are slipping and sliding up a moss covered rocky river bed, or a root infested wet clay single track with 3 learner housewives on xr200's in front of you?
As for KTM's in bogs - I prefer to ride over them, using them for traction. If you do it right they will still be there for the next lap and you can use them again. If you pull them out they will just roar off in font of you, shower you with crap, and hold you up.:)
Took the bike out with a 46 rear sprocket,to the Tarawera forest ride.Really liked it.Pulled longer through corners so didn't need to swap gears in tight stuff as much.The only down side was on long sandy hill climbs it could lose some revs.Just needed a little clutch to get it up in the revs again.Tarawera is a mostly flowing track so suited this gearing,could be a different story on some real gnarly single track.
