TheLetterJ
My '01 300 started making some "angry" noises as well as developing what I would call a lean surge while coming back down to idle near the end of my ride last weekend. The ride was entirely extremely tight and overgrown singletrack with big rocks and downed trees, temps in the high 80's-low 90's. The pipe was still tight at the flange with the bead of red RTV (I smeared some of it inside the pipe before sliding it over the exhaust flange/ o-rings) still intact so I pulled the pipe off to have a look in the cylinder. The cylinder walls looked burnt (brown streaks) and there was sticky gunk between the rings. I pulled the plug at the water pump and only ~1 cup of coolant came out... rut roh. I had given the bike its usual once over the day before including checking the coolant (which had not needed to be topped off at all since its last flush.) I blew steam a couple times during the ride, but not enough that I was concerned, I guess I should have been.
I had checked the topend out a few months ago (probably 170-180hrs then) when I replaced the pipe and all looked well, but I'm right around 200hrs now (I bought the bike ~3 years ago with the fuzzies still on the original tires) so I can't be mad that it needs its first piston... I'm sure it would have gone much longer if I hadn't blown all my coolant out! I was worried that I'd need a replate, but the cylinder cleaned up really good with some WD40 and a green Scotch Brite pad. My snap/bore gauge isn't big enough to accurately measure the cylinder for roundness/ taper, so I'll have my machinist measure it and then I'll know for sure if it's still good.
It's kind of ironic that this happened on the very first ride running a different 2T oil. I have been exclusively running Champion WP2 in all of my 2T's since about '03 but I finally ran out (I had been buying it 6 gallons at a time) and needed something for the weekend and figured 927 was a safe bet. I am not saying that this caused any of my issues, but I sure had a lot of spooge inside the powervalve cover and in the exhaust that I NEVER had before.
Oh well, I can't be upset, it's still the most reliable offroad bike I've ever owned and my favorite powerplant for tight terrain, it's totally worth putting money into. At least this is a good opportunity to finally have the head cut and a few other minor "upgrades" while I've got things apart. The only bummer is that I'm spread pretty thin right now so it will be a while before I can put any money towards fixing it.
