Only problem I have ever had was on my '07 with the original parts, '00, '03, and replacement '07 parts were/are fine. What I heard was that some springs were weak, and prevented positive engagement of the rachet, causing it to slip. When it slips it gets damaged slightly and things get worse until it slips a lot. If you notice it slip replace the spring ASAP and you might be good. IMO its perhaps more than that, some soft parts maybe. If you actually stripped splines from the shaft I would say definetely a problem with the hardness of part. I replaced everything about three years ago and mine is fine now. Also, some guys aggrevate this issue with the way they start the bike, or bikes in general. If you "slap kick" the bike, that is just slam the starter down fast without slowly engaging the rachet first, your asking for trouble.
